Terraform export
Hi all,
I have setup my environment variables:
DYNATRACE_ENV_URL
DYNATRACE_API_TOKEN
DYNATRACE_ENV_URL
After running my command:
terraform-provider-dynatrace_v1.23.0.exe -export dynatrace_mobile_application
I’m getting this lines
Post-Processing Resources…
exec: not started
I have Windows 10, 64 bit.
I downloaded the 1.23.0_windows_amd64
Any ideas how to troubleshoot ?
Abner
Hi Abner,
Depending on what version of Dynatrace (SaaS, Managed) you are using you will need to set this up dt_env_url:
  • Managed: https://{environmentid}.live.dynatrace.com/
  • SaaS: https://{environmentid}.live.dynatrace.com
In the next step, generate the appropriate token with below permissions:
  • Read configuration
  • Capture request data
  • Read SLO
  • Read settings
  • Read API tokens
  • Read entities
  • Read Geographic regions
  • Read network zones
  • Read synthetic locations
  • Read synthetic monitors, locations, and nodes
  • Read credential vault entries
  • Access problem and event feed, metrics and topology
  • Write settings
  • Write API tokens
  • Write entities
  • Write network zones
  • Write SLO
  • Write synthetic locations
  • Write credential vault entries
  • Change data privacy settings
  • Create and read synthetic monitors, locations
  • Write configuration
Example of provider configuration:
provider "dynatrace" {
    dt_env_url    = "https://{environmentid}.live.dynatrace.com"
    dt_api_token  = "################"
Radek
DYNATRACE_ENV_URL is the URL for your Environment:
https://{your-domain}/e/{your-environment-id}/e/{env_id}
