Terraform provider
I am trying to user terraform dynatrace but have an issue with terraform init.
Initializing provider plugins…
- Finding dynatrace-oss/dynatrace versions matching “1.55.1”…
│ Error: Failed to install provider
│ Error while installing dynatrace-oss/dynatrace v1.55.1: could not query provider registry for Terraform Registry failed to retrieve authentication checksums for provider: 403 Forbidden returned from objects.githubusercontent.com
I tried with different versions but it is the same error every time. Other providers I can install normally.
I have also configured this:
provider “dynatrace” {  dt_env_url   = “”  dt_api_token = “”}
After getting debug logs, I can see this:
2024-06-27T15:26:51.373+0200 [DEBUG] GET https://github.com/dynatrace-oss/terraform-provider-dynatrace/releases/download/v1.55.1/terraform-provider-dynatrace_1.55.1_SHA256SUMS
it is going to github, while for aws it is going to:
https://releases.hashicorp.com/terraform-provider-aws/5.55.0/terraform-provider-aws_5.55.0_SHA256SUMS
The first link is blocked because of private network, but again why there is such a difference
Hi @danijela
Try a provider configured like this:
terraform {
    required_providers {
        dynatrace = {
            version = "1.48.1"
            source = "dynatrace-oss/dynatrace"
provider "dynatrace" {
    dt_env_url    = "https://{environmentid}.live.dynatrace.com"
    dt_api_token  = "${QA_TOKEN_ENV_VAR}"
You can set your environment variables for proxy & token outside of the main.tf
Goodluck
