The process’s command-line arguments need to be displayed in the problem
I’m using a Metric event to monitor processes via the metric selector builtin:pgi.availability.state.
My question is whether it’s possible to somehow add the “Command line args” value to the created problem. This value appears in the process details, but it cannot be added as a dimension.
Is there a way to use a tag or something else, or is this simply not possible and I would need to build log monitoring from scratch in order to get this detail into the problem?
You can using oneagentctl to ingest custom metadata.
Best regards
hi,
thanks, but I think this is for a static value, right? I need to capture the command-line arguments for processes like java.exe. There are multiple processes running, their command-line arguments differ, and they change over time.
Br,
Michal
You have a dynamic value placeholder, but value is taken from process group, not process groups instance:
Best regards
