Hello Community
How can I put a threshold to 5min (Example), knowing that we have limitation on this fixed Threshold at 100 000ms
Thanks and have a good day.
Hello Community
Hello @Malaik
This is limiting us to putting the value more than 100 seconds. If you are interested to get rid of the request (key request) then, you can totally mute or you can play around with the below settings.
Babar
