Threshold's for a metric using custom event
Hi Team,
Is it possible to set-up two thresholds(Caution/Danger) for a single metric, using custom event ??
Amit Singh Bisht
2 different custom metrics should be defined for this need.
Hi Malaik,
So we can’t define 2 threshold for 1 custom metric.
Amit Singh Bisht
You can create, but it will result you with two alerts when the most critical (high sensitive) threshold hits.
That’s because you can only set “below” and “above” and not “between” thresholds.
Similar question was also posted here:
https://community.dynatrace.com/t5/Alerting/Threshold-Based-custom-alerts/td-p/183182
Take a look on the suggestion from @DanielS here, using SLO..
No I mean, crating 2 different custom metrics for the same purpose with 2 different thresholds.
Because in the settings, you have only below/above and not between.
