I’ve read the documentation and looked at the very limited examples available in the docs, but I still just do not understand what the “Extracted ID pattern” in the Entity Extraction Rule section of configuring Topology Types is and does.
For example, the CloudFlare extension has a type called cloudflare:zone and the Extracted ID pattern for that is:
cloudflare_zone_{zone_id}
and the Instance Name pattern for that extraction rule is:
Cloudflare Zone - {zone_name}
When I look at entities created by the extension, I see the Instance Name pattern, but I don’t see the Extracted ID pattern anywhere. So, I thought, “Ok, so maybe the Extracted ID pattern comes from the metric dimensions somewhere.”, so I looked at the metric dimensions that this type pulls from and nope, no dimension has any kind of key or value that looks like “cloudflare_zone_{zone_id}”. The metrics have a Zone ID dimension and a Zone dimension, but no dimension that has that pattern type as a key or value.
So, what in the world is the Extracted ID pattern used for and where can I see it?
