Trigger alert only during a specific time frame
Hi all,
We have a requirement for creating an alert which should only trigger for a particular time frame. Could you please suggest a solution? Please let us know if there is any option in Dynatrace for the same.
Vrinda
As a workarround, you can create maintenace windows for entity involved, and alert only would be created when it is not under maintenance window.
Best regards
