I’m trying to publish my Spring Boot application metrics using micrometer. I have completed adding required code and on running the code, I see the following error:
[dynatrace-metrics-publisher] ERROR io.micrometer.dynatrace.DynatraceMeterRegistry.lambda$postCustomMetricValues$6 (249) - failed to send metrics to dynatrace: {"error":{"code":400,"message":"Could not map JSON at 'series[56].dataPoints' near line 1 column 12884"}}
Hello! I just wanted to let you know - and for future references - that we have published a new version of the micrometer registry for Dynatrace: https://micrometer.io/docs/registry/dynatrace, with simplified deployment and that automatically connecting your Micrometer metrics to the topology.
