I’m looking at monaco deploy of EasyTrade: easytrade/monaco/config/bizevent-capturing/config.yaml at main · Dynatrace/easytrade
It deploys without problems, but what I don’t understand is:
- id: http-dotnet<br>config:<br>template: &template oneagent-feature.json<br>skip: false<br>parameters:<br>featureKey: SENSOR_DOTNET_BIZEVENTS_HTTP_INCOMING<br>type: &type<br>settings:<br>schema: builtin:oneagent.features<br>scope: environment
- What it means “&type” and what it means “*type” (the other configs are similar, but instead of “&type” there is “*type”).
- How we choose the name of the feature key?
- As far as I understand these keys are used to generate business events from requests - how can I filter the bizevents which are generated by for example the key given above: “SENSOR_DOTNET_BIZEVENTS_HTTP_INCOMING”
This is the json of the template:
This is the json template:<br>{<br>"enabled": true,<br>"instrumentation": true,<br>"key": "{{ .featureKey }}"<br>}
Thanks!
Regards, Deni
