Unzipping a file with newest DT capability
I currently am asked to download some trace log from SAP CPI API.
The called API gets back a log file in a .zip format.
Is it possible to download and unpack the zip in the same code snipped via some Dynatrace feature to then ingest those log data?
Regards
Hi @y_buccellato ,
Yes, this is possible. Let me give you a rough outline of what you need:
The handling of the ZIP file is the most tricky part. I just tried zip.js and came up with the following snippet for an app function:
<span>import</span><span> { </span><span>BlobReader</span><span>, </span><span>TextWriter</span><span>, </span><span>ZipReader</span><span> } </span><span>from</span> <span>"@zip.js/zip.js"</span><span>;</span><br><br><span>export</span> <span>default</span> <span>async</span> <span>function</span><span> () {</span><br><span>  </span><span>const</span> <span>zipFile</span> <span>=</span> <span>await</span> <span>fetch</span><span>(</span><span>"https://developer.dynatrace.com/zips/gettingStarted/finalproject.zip"</span><span>);</span><br><span>  </span><span>const</span> <span>blob</span> <span>=</span> <span>await</span> <span>zipFile</span><span>.</span><span>blob</span><span>();</span><br><span><br>  </span><span>const</span> <span>reader</span> <span>=</span> <span>new</span> <span>ZipReader</span><span>(</span><span>new</span> <span>BlobReader</span><span>(</span><span>blob</span><span>));</span><br><span>  </span><span>const</span> <span>entries</span> <span>=</span> <span>await</span> <span>reader</span><span>.</span><span>getEntries</span><span>();</span><br><span>  </span><span>for</span><span> (</span><span>const</span> <span>entry</span> <span>of</span> <span>entries</span><span>) {</span><br><span>    </span><span>if</span><span> (</span><span>entry</span><span>.</span><span>filename</span> <span>===</span> <span>"finalproject/package.json"</span><span>) {</span><br><span>      </span><span>const</span> <span>textWriter</span> <span>=</span> <span>new</span> <span>TextWriter</span><span>();</span><br><span>      </span><span>await</span> <span>entry</span><span>.</span><span>getData</span><span>(</span><span>textWriter</span><span>);<br></span><br><span>      </span><span>console</span><span>.</span><span>log</span><span>(</span><span>"This is the content of the package.json file:"</span><span>);</span><br><span>      </span><span>console</span><span>.</span><span>log</span><span>(</span><span>await</span> <span>textWriter</span><span>.</span><span>getData</span><span>());</span><br><span>    }</span><br><span>  }</span><br><span>}</span>
Just adapt the filename check, and you should be able to extract the data you need.
Also, remember that you don’t have access to the file system within an app function, so everything you do needs to be in memory.
Let me know if this helps!
On the function documentation I’m reading that there are few limitation.
I’m particular interest in this one:
  • Function inputs/outputs can’t be larger than 5 MB, respectively.
Suppose the first API call will give me back a 15 MB .zip file, am I already breaching the current function limit?
Thank for the previous reply, I appreciated it
The input refers to the payload you can send to the function, and the output is what you return from the function.
A fetch request to an external service is not impacted by these limits.
Thank you very much - a lot of learning and nuance (also due to language barrier) for me.
I’ll do my best
Is the javascript code you posted applicable in a workflow step?
When I select a “Run Javascript” and paste/execute the code I have a reply back
An error occurred: {"code": 541, "message": "Execution crashed.", "details": {"type": "BAD_REQUEST", "message": "<stripped secret anyhow::Error>"}}
Which is leading me to think that I need use another approach.
PS from work flow I’m able to download the first zip file but then I don’t know how to reference the previous downloaded file to unzip it :slightly_smiling_face:
No, it won’t work in a Workflow step. You currently can’t use third-party libraries in Workflows.
However, you can create an app with this logic in an app function, and then call it from a Workflow step.
Just an update to give you my impression: when I became aware that I didn’t exactly get you the first time, I decided to start from scratch and followed the DT tutorial on some of the documentation page.
Doing it this way I better understood the fundamentals and also where an app function must be placed to execute the logic (though I don’t fully understand why should I create an entire app if I only need an app Function to execute some specific logic likely to be “Take some data, manipulate it, push some data to DT as logs”).
In the end I think I managed to configure the first part of the logic which was to do a Get, retrieve a zip and unzip it - definitely also thanks to your original answer - but I think I will stop here and look for an alternative solution.
In my prev. experience I was going with bash and recently I went with Power Automate and I thought I could find a similar friendly environment for my case. Here it appears I need to have a low to mid experience in the developing field which I can grow in time but I don’t have immediately at my disposal.
For time and daily tasks reason I will put an hold on this but overall it was a good experience.
Thank you for your help and time,
regards
