Summary: This post discusses alternatives for separating environment‑specific dashboard content when env variables cannot be used. It includes filtering techniques and tile‑based approaches.
Dynatrace is detecting multiple similar processes in the host and putting them under the same process group and instance.
I used the environment variable “DT_NODE_ID” at the host level to separate these processes, but I have to give these environment variables to each process at every reboot of the Linux machine.
Is there any alternate approach to this problem? The metadata, like EXE path, command line args, is the same for these processes.
Both the processes that I want to separate have the same EXE path. The only difference being that they run on different ports. Is there a way to separate them?
