As the mobile app will soon be end-of-support, I am now testing the workflow that send notification to Teams whenever there are problems being triggered.
However, I do not want to send every problem alerts to Teams. Only those which have Alert Profiles other than Default one assigned will be sent to Teams.
I have constructed a DQL query to do the filter. However, the workflow UI does not allow me to add custom DQL query. It only allows partial DQL filter input.
Is there any way I can use the DQL to do the filtering in Problem triggers?
