UseDQLQuery autoFetch property
UseDQLQuery autoFetch set to false still runs query on react component load. Why?
Hi Jwrogers,
can you please give us the code snippet to fully understand the usage?
I build the fetch bizEvents DQL in the method getPipelineSummary(), but I don’t want it to trigger until I call refetch().
useEffect(() => {
    setDetails(details);
    refetch();
const { data, isLoading, refetch } = useDqlQuery(
      body: { query: dbQueries.getPipelineSummary() },
    { autoFetch: false, autoFetchOnUpdate: false },
Hi there
When the component loads, it calls the `useEffect` hook. In this hook, you’re calling refetch. If you dont’ want the query to run when component loads, just remove that execution of refetch as following:
useEffect(() => {
I removed refetch from being called anywhere in my component, but it’s still being called when the component loads:
Hi there
Do you have full code snippet that you can share or codesandbox?
That’ll help me solve your issue much better.
