When using DPL, namely in Logs Classic, we sometimes have to check and convert values.
One great example is converting trap severity OID values into their corresponding loglevel’s in Dynatrace.
I have managed to make my first conversion, and it goes like this:
USING (INOUT "CISCO-SMI::ciscoMgmt.311.1.1.2.1.17.0":STRING ) | FIELDS_ADD( loglevel: (
case
when COLUMN("CISCO-SMI::ciscoMgmt.311.1.1.2.1.17.0") == '1' then 'CRITICAL'
when COLUMN("CISCO-SMI::ciscoMgmt.311.1.1.2.1.17.0") == '2' then 'ERROR'
when COLUMN("CISCO-SMI::ciscoMgmt.311.1.1.2.1.17.0") == '3' then 'SEVERE'
when COLUMN("CISCO-SMI::ciscoMgmt.311.1.1.2.1.17.0") == '4' then 'WARN'
when COLUMN("CISCO-SMI::ciscoMgmt.311.1.1.2.1.17.0") == '5' then 'NOTICE'
when COLUMN("CISCO-SMI::ciscoMgmt.311.1.1.2.1.17.0") == '6' then 'INFO'
else "NONE"
end
While I still want to confirm if these loglevel’s are the best match, I believe it is pretty self-explanatory.
BTW, the Cisco definition is:
1—Critical
2—Major
3—Minor
4—Warning
5—Clear
6—Info
Also, thanks for this great finding: https://community.dynatrace.com/t5/Log-Analytics/Log-Processing-CASE-WHEN-THEN-ELSE-END-Documentation/m-p/258434
