V2 Metrics API - Can I get Kubernetes CPU requests for a pod?
Hello DT Community,
It seems that in the V2 Metrics API that there is no way to get pod CPU requests. I can get pod CPU usage, pod CPU limits, pod memory usage, pod memory limits, and pod memory requests.
Is there a way to do this without doing a derived stat? Bigger question is there value in that stat?
Any advice is appreciated.
Thanks!
Hi @crabbylou,
I have not seen any problem with the Metric API regarding CPU request of a POD.
I used this metric selector expression at the Metric API:
Response part1:
Response part2, this pod has 1 core cpu requests:
Best regards,
János
Thanks for responding Mizso. Is there a way to get all the pods CPU requests for a namespace or workload?
The best I can get is the total. I cannot get it by pod name. The Classic UI graphs do a funky thing of taking the requests for the workload, and then divide by the number of running pods.
I can do this in Grail, because they have an actual stat to do that, but I am still tied to the V2 API for now.
Thanks!
Hi @crabbylou,
Unfortunately I do not know soultion for this request.
Maybe the other community members have any ideas about it.
Best regards,
János
