Hi ,
I want to measure cpu utilization of POD , which metric can used ??
Please suggest.
Heramb
Hi ,
Please suggest.
Heramb
please help me on this
Try dt.kubernetes.container.cpu_usage in DQL
Take a look at the new kubernetes app , you can drill into the metrics of interest in there and open them in Notepad for querying. It will help you understand
Thanks , this is helpful.
