A New Zealand partner (Fujitsu) asks if Dynatrace has an Alemba vFire integratiion planned, or if anyone is successfully directly integration with this service-management platform.
No such plans but by using our REST APIs all raw information is easily accessible from the Dynatrace side.
Team - Can you let us know if there is any update on integrating Dynatrace with vFire? Any references or samples ? Appreciate if you can provide any guidance on the Custom integration of the vFire
@Wolfgang B., @Graeme W. : Can you let me know if there is any update on integrating Dynatrace with vFire? Any references or samples ? Appreciate if you can provide any guidance on the Custom integration of the vFire tool with Dynatrace
No updates on vFire.
