Is it possible when you create a vmware connection config in Dynatrace to exclude certain clusters? Atm I can only find include filters. A $ne or $notcontains would be more beneficial then include filters like mentioned below.
- $prefix(parameter)
- $eq(parameter)
- $suffix(parameter)
- $contains(parameter)
Hi @David_A
Maybe the following operators can be use, please try / test them.
$not, $or, $and eg. $not($contains(production))
I have already used them at extesnions eg. F5 for filtering purposes.
You can find some examples on these links which ones related the OS service monitoring but I guess a logic is the same:
Settings API - OS services monitoring schema table — Dynatrace Docs
I hope it helps.
Best regards,
János
Hi Miszo,
Unfortunately only the 4 operators I mentioned in my post are allowed in the VMware connection config.
Should have one of the following formats: $prefix(parameter), $eq(parameter), $suffix(parameter), $contains(parameter)
Hi @David_A
I this case please submit a product idea. Product ideas - Dynatrace Community
Thanks in advance.
Best regards,
János
Thanks Mizso,
created an improvement request.
