Hello, can anyone help me with the correct pattern to filter virtual servers and pools on the f5 bigip extension?
I’ve trien * but it doesn’t work in any case like:
*/Common/app1*
/Common/app1*
*app1*
etc
*/Common/app1*
/Common/app1*
*app1*
etc
Hi @cjlugoa,
Could you please try match. I thnik you can use it at F5 extension also.
OS services monitoring — Dynatrace Managed Docs
I hope it helps.
Best regards,
János
Correct, actually here is the docs reference for extensions in general - SNMP data source reference — Dynatrace Docs
