Hi Folks,
Last week we upgraded two OpenShift clusters Dynatrace operators from 0.2 → 0.8.1. (Unfortunately, the client did not have the human resources to do it more frequently). It is a classicfullstack implementation (with operator hub) and with node selector limited only for the worker nodes. It seemed to go well, but after a few hours, the number of failed pods number started to slowly increase. We checked which pod is affected and turned out that Dynatrace-webhook pods failed within a few hours. When we observed it there were approx. 30 failed Dynatrace-webhook pods with the actual 2 running Dynatrace-webhook pods. Based on the following Kubernetes warn event it seems the ephemeral storage free space became 0%
“Pod ephemeral local storage usage exceeds the total limit of containers 10Mi.”
We increased the webhook pods ephemeral storage limit to 10Mi → 100Mi. The situation slightly changed. :-). Dynatrace-webhook pods survived more than a day but after that failed with the increased ephemeral storage too. + info these pods always started on Kubernetes infrastructure (role) nodes.
I do not know why these webhook pods started, I thought these type of pod required only for cloudenative and app only instrumentation.
Does anyone have any idea about this strange behavior of Dynatrace-webhook servers? Have you ever met this issue?
Thanks in advance.
Br, Mizső
