Weblogic metrics - StuckThreadCount
Hi all.
Is it possible to plot the weblogic StuckThreadCount metric?
I have seen that there is a Python extensions (EF 1.0) for this, but I have read that this kind of extensions will disappear soon.
is there any extension for these metrics on EF 2.0?
Thanks in advanced
JAR
I believe you still can use JMX extensions to create such metric, please check the below document.
Islam
Hi @JAR1 ,
For StuckThreadCount metric you should follow these steps. Prerequsite: WL have to expose the jmx metrics.
1. Add new technology monitoring
2. Add JMX extension.
3. Use the jmx extensions editor.
4. Add a metric source, select Oracle Weblogic.
5. Create the metric.
I hope it helps.
Best regards,
Mizső
@Mizső, super tutorial 😁
Thank you very much,
I know that extension , but my question focused on extension v 2.0.
Finally, i´ve convert the JMX extension v1 to v2 following this tutorial:
https://developer.dynatrace.com/extensions-v2/dynatrace-extensions-vscode/guides/jmx-conversion/
Hi @JAR1
There is now an extension called “Connection Pools : WebLogic” that has very useful metrics for Connection Pools and StuckThreads
Connection Pools: WebLogic monitoring & observability | Dynatrace Hub
NOTE: Only for Linux & Windows
I hope it’s helpful :flexed_biceps:
