What are the requirements for using Live Debugger?
What is required to enable Live Debugger?
Dynatrace Live Debugger is only available on Dynatrace SaaS deployments with a DPS accounts and are set to Full Stuck monitoring mode that has the ‘Code Monitoring’ rate card associated with the account.
It’s also worth mentioning that the configuration must be done according to the documentation: /live-debugger
