I’m new to the community. What’s the maximum number of environments I can create?
Abner
Abner
Hi @abnerlusung,
It is not an exact answer for your question but maybe you can find some useful informtion in this post:
Solved: Number of recommended environments - Dynatrace Community
I hope it helps.
Best regards,
Mizső
There’s no strict limitation on the number of environments. The better question is how much your cluster is capable of monitoring. The analogical question is “How many bags you can fit into your car?”. You can probably fit hundreds of empty bags, or almost empty, but just a few full bags. Same with the cluster:
- Plan you cluster capacity for max 50,000 hosts in total
- Each environment should have max 25,000 hosts monitored.
This means you can fit two full-blown environments into 1 cluster. We’ve not tested more than 2,000 environments.
For best cluster performance I recommend to have 1-2 environment in a Cluster.
But it is only my experience.
Romanenkov Alex
