where do I find data on "unmonitored process"?
Where do i find the list of un-monitored process in Dynatrace manage. As most of our requests are going to un-monitored processes.
Do you mean unmonitored hosts? Or you have host that is monitored and some of processes on it are not covered by monitoring?
Hosts is under monitored, but some of processes running on hosts it not monitoring.
I need to get a list of process which are un-monitored so i can ask application team to restart it.
There is no such list to export. Go to Deployment Status => All Hosts and there you will see marked those that have issues.
Ohh ok,
Thanks for your quick answer.
