Which Metric is used for Disk latency
I am trying to look specific metric or calculation used by Dynatrace for Disk Latency, especially for Windows Server.
Is it ‘Avg Disk sec/Read’ and ‘Avg Disk sec/Write’?
Hi @mengsuan_koe1
Within the host page (the new look), scroll to the Disk analysis part, check the metric you are looking for and click on the … next to the chart
There you will find the magic button Show in data explorer
HTH
Yos
I am wishing to find out how does the OneAgent collect Disk Latency data from Windows server. It should be a perfmon metric I assume.
I think for Windows it should be WriteTime / WriteCount from DeviceIoControl(IOCTL_DISK_PERFORMANCE) and the same for ReadTime / ReadCount
