If you encounter connection issues:
- Make sure you have configured the correct URL, matching your environment.
- See if you have a network security layer (for example, a firewall or a proxy) blocking connections to port 443.
- Make sure you can reach the ActiveGate instance (for example, using ping).
- Make sure your system’s root SSL certificates are up to date, and apply OS updates if necessary.
When exporting to a local Environment ActiveGate instance, remember that this setup uses a self-signed certificate for the HTTPS endpoint by default. If you encounter SSL issues, do one of the following:
- Add the certificate to your exporter’s truststore.
- Configure your exporter to ignore the broken certificate chain and continue with the SSL connection. This option is less secure.
