Why does my OTLP export not work?
If you can’t export OTLP data, make sure your exporter is configured:
  • To use OTLP over HTTP. OTLP over gRPC is currently not supported.
  • To use Protobuf encoding. JSON is currently not supported.
  • With the correct Dynatrace API URL (ActiveGate or OneAgent) and token (ActiveGate only).
