Workarounds for placing Key Requests in Maintenance Mode?
Hi team,
Has anyone successfully placed a specific Key Request into maintenance mode? I’m currently unable to do this directly.
I am aware that I can adjust thresholds or mute the specific request, but I am looking for a true maintenance mode solution if one exists.
Does anyone have a workaround for this?
I would say mute request.
Or as it is key request, swith off failure rate and anomaly detection settings only for that key request.
Best regards
you can prolly expand what @AntonPineiro outlined and make a workflow to execute the “turn back on” action.
Great question!
Thanks to you both.
Next question - maybe I should put in a separate post:
How about otel and end points.  No option for muting or key requests.
good point, Otel - is that data feeding into a custom entity? - if so, you should be able to target that
Exactly what I was thinking but wanted to confirm with others.
yes, endpoint.  part of span.
Let me make a separate post for this since it is different
https://community.dynatrace.com/t5/Open-Q-A/Place-a-endpoint-from-OTel-in-maintenance-mode/m-p/291712#M38258
