I would like to create workflow to filter only some problems base on title.
Workflow problem trigger allows filtering only base on entity tags. I would like to filter only some events base on title. My question is:
- Can I use “Additional custom filter”?
- Do I need to create a Javascript task for filtering in/out?
Thank you!
Best regards
Hey, you can open Advanced options --> Additional custom filter
sonja
3
In addition to what @dylan_taelemans showed, you might want to consider using the matchesPhrase operator: DQL matcher in OpenPipeline — Dynatrace Docs
Thank you both! Yes, I was able to filter using option 1. Using DQL matching “event.title”.
Best regards
