Workflows 1.3537.6 – Davis problem trigger event.id is now the display ID (P-…)? Not in release notes
Hi all,
After the Workflows app updated to 1.3537.6 (published 4 Nov 2026), our custom Davis problem → ServiceNow workflow stopped working. The cause was a change in the trigger event that I can’t find in the release notes, which only mention expression autocomplete previews and the new maintenance-window option for Davis problem triggers.
What I see:
  • Before: event()[“event.id”] was the internal problem ID, e.g. -7228652111118287103_1794343200325V2
  • Now: event()[“event.id”] is the display ID, e.g. P-2611101
  • The internal ID is now only available as classic_problem_id (dt.davis.problems / trigger payload), and dt.davis.event_ids holds the underlying Davis event ID(s)
Side effects:
  1. problemsClient.getProblem({ problemId: event.id }) fails, because the classic API doesn’t accept P-2611101.
  2. The classic API’s display ID for the same problem is different (P-26111 vs P-2611101 in Grail), so a displayId(“…”) selector lookup returns nothing.
  3. CUSTOM_ANNOTATION events with annotation.problem_ids = no longer show on the problem in the new Problems app. They only appear when annotation.problem_ids = the P-… display ID.
  4. Problem links built as /ui/apps/dynatrace.davis.problems/problem/ now show “Failed to load problem”. /problem/P-… works.
I’ve worked around it. But we’d like to confirm:
  1. Is the event.id change intentional, and is it going to stay?
  2. Which identifier should workflows use as a stable, long-term problem ID for external systems: event.id, display_id or classic_problem_id?
  3. Is classic_problem_id guaranteed to remain in dt.davis.problems and the trigger payload?
  4. What is the supported way to attach annotations/comments to a problem in the new Problems app from a workflow?
  5. Why do the classic and Grail display IDs differ for the same problem?
  6. Could the release notes be updated to call this out? Other custom workflows using getProblem(event.id) will break the same way.
Sujit
