Writing a negate for Launchpads
Hey Community,
Launchpads are great, but there are limitations - like number of launchpads that can be created. To this point, I’d like to remove the ability for staff to make these launchpads. Much like the ability to remove presets and staff setting things as presets in dashboards.
I made a policy that had Denys but its not preventing the creation of net new launch pads:
Anyone have ideas to get this to work? I also dropped off the allow so its just a deny, but its not working as expected
Hello @ChadTurner ,
I believe this is more related to the document service so you might also consider using document:documents:write
Best regards,
Hamdy
You are right @Mohamed_Hamdy. The only issue is that Notebooks, Dashboards and Launchpads are considered Documents. Deny access to one Denys Write access to all. So I’m now looking at how to Isolate down to the particular App being Launchpad and Denying Write, while allowing Write on the other document levels.
