Pin Launchpad for All Users
I created a launchpad that centralizes all dashboards with a description of what exists in each one to facilitate navigation for users less familiar with the platform.
I pinned this Launchpad into my dock, but I would like to pin this Launchpad for ALL users that will login in this this tenant. How can I do this?
Dynatrace is working on it, you are little too early, i will update you in this thread when will be GA.
The only way to “start” doing this is to lump all your users into a single grouping for the Launchpads, then Add in the associated Home Launchpad for the users.
There is a product idea, please vote for it
https://community.dynatrace.com/t5/Product-ideas/Change-Default-Launchpad/idi-p/268724
As others are alluding to, you can configure a “Home Launchpad” for a given user group, which will get highest priority. Not sure if this would suit your environment, but might be worth experimenting with to see if this meets your needs. The setting for this is located in the ‘New’ Settings app, under Apps > Launcher.
