We will be integrating IBM DataPower ActiveGate extension, but ports are not mentioned in the documentation. Shouldn’t there be a specific port to be opened from the DataPower side to pull the data from?
You need to have network connectivity towards the DataPower XML management interface, which by default is tcp/5550. It’s maybe worth making sure that you’re using that default port, before implementing the firewall rule.
I gotta agree with you, when it comes to extension or plugin, the DT documentation isn’t very completed in terms of ports used.
