Hi, I want to test ActiveGate extension to check socket connection. Has anyone tested this extension? Is there a document I can refer to?
Swati
Swati
Hi, do you mean the port check extension linked from this blog post? Easily monitor your entire infrastructure with Dynatrace Synthetic monitors
It’s used by several customers already if so.
Mike
