Endpoints in Datapowers
Does Dynatrace Datapower extension monitor https endpoints? Is there a way to see what the Datapowers outgoing connections are?
Hi Matthew,
Yes, it’s possible to monitor https endpoints using Datapower extension. Here it’s an example:
And once the endopoint is monitored you can watch the outgoing connections:
Hope it helps.
Elena
Hi @matthew_k
Kindly follow the attached configuration steps as per Dynatrace hub:
IBM Datapower monitoring & observability | Dynatrace Hub
It should work as expected and achieve the desired monitoring purpose.
Make sure deployed Activegates are able to reach the IBM endpoints.
  • ActiveGate with the Extensions 2.0 module enabled.
  • IBM Datapower appliance with the XML Management Interface enabled.
  • User with access permissions to the XML Management Interface.
