Hi Community,
I’m havin trouble finding the documentation for AWS-speciffic monitoring config options.
The config.txt file lists the following, but I could not find the relevant documentation online.
#vtMemoryProtectionCredentialsLimit = 500
#aws_cloudwatch_bulk_size = 500
#aws_cloudwatch_bulk_max_threads = 32
#aws_cloudwatch_bulk_desired_total_time_seconds = 45
#aws_service_query_timeout_s = 180
#aws_client_desired_infra_polling_duration_s = 180
#aws_cloudwatch_query_rate_per_second = 50
#aws_throttled_infra_executor_enabled=true
#aws_sdk_client_max_connections = 50
#tagging_api_enabled = true
#aws_disabled_services=“S3;RDS;LoadBalancer;LambdaFunction;InstanceState;ELB;EC2;EBS;DynamoDB;Beanstalk;AutoscalingGroup”
#aws_infra_scheduler_enabled = false
#aws_infra_scheduler_min_query_period_ms = 10
#aws_infra_scheduler_default_query_period_ms = 100
#aws_infra_scheduler_max_query_period_ms = 1200
#aws_infra_scheduler_max_child_query_period_ms = 10000
#aws_infra_scheduler_random_spread_window_ms = 5000
#aws_infra_scheduler_executor_threads = 5
#generic_service_metrics_null_as_zero = true
#last_seen_based_back_polling = true
metrics.ingest_delay.AWS/Route53Resolver.OutboundQueryAggregateVolume = 10
metrics.ingest_delay.AWS/NATGateway.BytesInFromSource = 5
metrics.ingest_delay.AWS/NATGateway.BytesOutToSource = 5
metrics.ingest_delay.AWS/NATGateway.BytesInFromDestination = 5
metrics.ingest_delay.AWS/NATGateway.BytesOutToDestination = 5
#aws_client_thread_pool_keep_alive_time = 30 # seconds
#aws_client_core_thread_pool_size = 40
#aws_client_initial_throttled_thread_pool_size = 10
#aws_client_parent_thread_pool_size = 10
#aws_client_core_thread_pool_timeout_enable = false
#time in seconds after AWS client will try to increase polling speed when not completed
#aws_throttled_infra_executor_speedup_time_s = 230
#how much (in percent) increase infrastracture polling threadpool size when not completed in aws_throttled_infra_executor_speedup_time_s seconds
#aws_throttled_infra_executor_speedup_increase_percent = 200
#aws_client_thread_spread_windows_size = 5000
#cloudtrail_config = <clientId> ; <label> ; <sqsArn1> [; <sqsArn2> [; …]]
#aws_client_tenant=1
Please could you point me to a document that explains each option?
Kind regards,
