Sure — I would answer like this:
I would start with the basic, repeatable configuration items that help establish standards across the environment:
- auto-tags,
- management zones,
- host naming,
- process group naming,
- service naming,
- basic alerting profiles,
- notification integrations,
- optionally some baseline dashboards
These are good first targets for Terraform because they help standardize the environment early and avoid manual differences between applications, teams, or tenants.
I would not try to manage everything in Terraform from day one. Start simple: create a few baseline modules, onboard one application or one team as a pattern, validate that naming, tagging and MZs work correctly, and only then expand.
Once the basics are stable, you can move to a more advanced approach using modules, variables, for_each loops, multiple environments, more complex alerting, SLOs, request attributes, custom anomaly detection, dashboards per team/application, etc.
So my recommendation would be: start with standards and foundations first, then gradually automate the more complex configurations.
Later, you can go one step further and start templating the configuration using variables, conditions and dynamic blocks.
For example, you can have a separate environment file:
# environments/prep.tfvars
environment = "PREP"
auto_tag_name = "Tomek_terraform_new_template"
kubernetes_namespace_value = ["tomek"]
synthetic_monitor_name_value = "Tomek_synthetic_new_template"
mode = "FULL"
external_monitor_name_value = "Tomek-external-monitor_new_template"
Then, inside the module, you can use conditions and dynamic rules, for example:
dynamic "rule" {
for_each = var.synthetic_monitor_name_value != null ? [var.synthetic_monitor_name_value] : []
content {
type = "ME"
enabled = true
attribute_rule {
entity_type = "BROWSER_MONITOR"
attribute_conditions {
condition {
key = "BROWSER_MONITOR_TAGS"
operator = "TAG_KEY_EQUALS"
tag = var.auto_tag_name
This allows one module to support multiple use cases: Kubernetes, synthetic monitors, external monitors, web apps, databases, etc. You only control the behavior through variables and separate .tfvars files per environment.
