I see the docs here show what can be configured and built via Terraform, but not everything can be built yet.
Is there a road map for Dynatrace Terraform Provider?
There is also an issue on the Github related to this:
Specifically, I am looking to see when SLOs can be built via Terraform.
Thanks.
Id toss in a RFE asking for this functionality. the Product developers will see the request and update you.
For anyone that sees this question, here is the information I currently have:
Reinhard Pilz responded to a ticket I opened up with Dynatrace about this. This is what he said:
Currently our short term milestones are
By the end of May 2021
Custom Anomaly Detection
Service Naming
Mid June 2021
Service Level Objectives
By the end of June 2021
Environment Creation
In general the settings that are getting supported next highly depend on feedback from the community. If there is a specific kind of setting that’s not yet covered but would be of importance for you to use the terraform provider effectively in your environment, please create an issue on the GitHub repo.
Hi all, I’d recommend looking into Monaco as this does support SLOs today.
Please check it out at Terraform Registry
