I’m working with the Business Events Grail endpoint via OAuth Client Authentication. The returned expiration is set at 5 minutes… Do we have the ability to increase that time?
API Tokens are different but thanks for the reply.
OAuth bearer token is the new Grail authentication method
Hi @Nick-Montana,
due to security reasons, the expiration is set to such a low value as 5 minutes and it is not possible to increase this.
This is where you see the 300 coming when you request a the token from the DT SSO Url. Whe about long is this token valid for in its life time?
