Hi
I am using a Table visual in a Dashboard where I can succesfully change the background colour for columns that are numerical by configuring thresholds
Is it possible to drive colour changes based on “text” values? see screenshot example - it would be for my “Status” columns in attached imaged
I cannot see a way of doing this? is it possible? any workarounds?
Apprecaite your time
Alan
@AlanFoley You should be able to do that via thresholds, see below example
Thanks Phani - not sure how I missed that
- works great thanks
One limitation however is that there is one global setting for either highlighting the “Value” or the “Background” for all columns in the table - its basically a global “either” “or” setting - it would be great is there was an option for each threshold column to be able to define either “Value” or “Background” highlighting - this would allow more flexibility
Appreciate the help
