When I extended monitoring using the Powershell SDK monitoring mode, the following error was reported:
Python datasource initialization error: Exception(“Could not run a test powershell script: ‘NoneType’ object has no attribute ‘stderr’”),
How do I fix it? thank you.
Ref from external site
If code is written like this
def get_shape_of_object(obj):
return obj.shape
value = None
print(get_shape_of_object(value))
should fix into below example
if obj is None:
return None
return obj.shape
value = None
How to Fix AttributeError: ‘NoneType’ object has no attribute ‘shape’ (appdividend.com)
How to Fix the ‘NoneType’ object has no attribute: ‘text’ Error in Python - Nsikak Imoh
Cheers!
RN
