Content section is missing in Logs which was available earlier. Is this related to some settings or permission issues. Any help is much appreciated. Thanks in advance.
Do you see ‘content’ under the ‘Fields’ section at all?
Assuming you have verified that the content field exists on the log event(s) in question (in a Notebook via DQL query, for example), you might try resetting the app state of the Logs app, just in case something has gone wrong with the app’s internal rendering logic.
Steps:
- Navigate to Hub app
- Click ‘Manage’ tab
- Find the Logs app and click the three dots
- Select ‘Reset state’ option, and then review & follow prompts
Hi, I just see ‘Topology’ and ‘Fields’ sections and nothing below that.
I was referring to ‘content’ in the ‘Fields’ section, is that showing up?
Have you tried @marco_irmer’s suggestions?
Check if your logs contain the ‘content’ field via a basic Notebook DQL query e.g.:
fetch logs<br>| limit 20
You should see log records; if they have the ‘content’ field, try the suggestion to reset the app.
Alternatively, use the Logs & Events Classic app to check if the content is present.
