Cross-environment oneagent feature issue
Hi Folks,
Some weeks ago I tested the cross environment oneagent feature. When I turned on I received unexpected low load problems at some services, screenshot is attached. Simply the services traffic were not collected.
This was the result at some services:
I raised a support ticket, but it has not solution yet. I have received a question form support:
“Do you have a PPDUMP file of a sampled path?”
I have not heard about PPDUMP file and I have not got any explanation about it from support. Is it a Pure Path dump file? or Is it something else? Do you know how can I create PPDUMP file?
Thanks in advance for your help.
Best regards,
Mizső
Afaik ppdump is a purepath export from the DebugUI - which is not something you can do on your own.
Hi @Julius_Loman,
Thanks very much for your switf response.
It’s true I do not have access to the Debug UI. I have seen the Debug UI menu item once during a demo which was held by Thomas Brandl.
I’m going back to the support with this info… :wink:
Best regards,
Mizső
