I am trying to configure custom alerts for a service’s processing time. These alerts are based on a calculated service metric I created that allows me to filter request data by certain dimension; request attributes.
I have configured this alarm end-to-end and gotten an alert to successfully fire under the condition I configure the alert using the ‘build’ option (filtering by only a single dimension value):
When I try to create a very similar alert using the ‘code’ option (because I need to filter on multiple values for the dimension, which doesn’t seem possible using the ‘build’ option), I get a preview that indicates alerts should fire, but they never actually fire:
The settings for the two alarms are identical, in that:
- They have identical static threshold settings
- They have identical severity settings (Slowdown)
Where they differ is:
I used the ‘build’ option for one and the ‘code’ option for the other.
For the alert that uses the ‘build’ option, I am able to set entity scopes for the alert (such as management zone).
For the alert that uses the ‘code’ option, I am unable to set these entity scopes (i.e. I can’t select management zone from the dropdown).
My leading theory is that the issue lies with the fact that the code-based alert does not have a management zone entity set (it doesn’t seem to let me set one). As a result, the alert doesn’t match the management zone for my alerting profile, and therefore I don’t get an alert.
How would I associate a code-based alert with a specific management zone, such that it is picked up by the alerting profile when the alarm fires? Is there something I can add to the metric query?
