Custom solution for default fields
Hello Team,
I am trying to setup new Dynatrace Env. and I would like to use my custom fields payload instead of content.
So, whenever I ingest the data my logs should be shown in payload and I dont want to use content as a fields.
Is there any way to implement this?
@anuj08_jain If your requirement is to display a different field name instead of default when querying , you can try something like below
fetch logs
| filter matchesValue(dt.system.bucket, "XYZ")
| fieldsRename Payload = content
Alternative way would be to use the OpenPipeline processors to rename fields
