Is there a way to monitor Informatica using Dynatrace?
Informatica has a range of different products: https://docs.informatica.com/
Can you clarify what would you like to monitor with Dynatrace?
Hi Radoslaw,
I have the same question, we are using “Informatica PowerCenter”
https://docs.informatica.com/data-integration/powercenter/10-5-4.html
There is now a Dynatrace extension which monitors completed and long-running Informatica jobs by polling the Informatica API.
