Informatica monitoring with Dynatarce
Please provide the details if Dynatrace can monitor Informatica 7.0 ? If it can what all metrics it can capture?
Chandni
Hi @Chandnipatel
You can start using the extension
Hi @Malaik
Thanks for the quick reply. I did not come across the Informatica version compatibility with the DT extension. Client is using Informatica 7 as a job scheduler.
Not sure if I am missing anything.
Could you please guide me through the same?
Chandni
Nothing mentioned about the version, so you can test it.
Its very fast to do
