do you have any experience in Dynatrace working with Informix Database? I don’t see any available plugin , so , is there cirrently any way of getting visibility of Informix work?
Thanks in advance.
Alberto.
Thanks in advance.
Alberto.
Hello Alberto,
Can you be a bit more specific? Are you asking if Dynatrace has the ability to monitor Informix databases?
Yes, that’s what I want to know, if Dynatrace is able to monitor Informix DBs. In the papers, It’s no a supported technology but I just wanted to know you experience monitoring Informix.
Thanks.
Alberto.
Hi Alberto,
Personally I don’t have any experience monitoring Informix databases, but Dynatrace should have the ability to monitor them. Whether you can monitor them all depends on the technology you are using and how that technology is calling the database. You’ll first want to make sure that the application making the call has deep monitoring enabled. After that as long as the processes making the calls are Java, .Net, PHP, or Node.js and the interaction with the database relies on a supported database framework you should be able to achieve monitoring of an Informix database. I’ll place a link below with more info on DB activity monitoring.
https://www.dynatrace.com/support/help/shortlink/database-detection
Hope this helps!
Gotcha, no problem ^.^
