Good morning.
I have two applications using the same domain.
xxxx.com.br/apl01
xxxx.com.br/apl02
How to separate these two environments?
Generally you need to work on setting a suitable condition e.g. “Contains”, “Start with”, which will apply to the unique part of the URL or Domain.
Details on how to configure these rules and good practice can be found here:
Radek
Hello Mizső
Yes, it helps, in fact I was wondering if Dynatrace would understand /ap01 and /ap02 as a domain extension.
Hello Radek
Thanks for the info.
