Hi, currently in Dynatrace, creating an application is a tedious process of selecting 1 rule at a time.
Can the application rule definition be made easier by allowing to select multiple conditions. At the moment, I have the following problem
We have 3 applications running on the same application server, the name of the applications are Application — AI for All., Application — AI for All. and Application — AI for All..
This is in the live system, we then have the following applications in our test environment, t-application.com/abc, t-application.com/def and t-application.com/ghi.
How would I be able to differentiate the 3 applications in the live system from those in the test system?
I would like to create 6 different applications namely:
| ABC_Live | Application — AI for All. |
| DEF_Live | Application — AI for All. |
| GHI_Live | Application — AI for All. |
| ABC_Test | t-application.com/abc |
| DEF_Test | t-application.com/def |
| GHI_Test | t-application.com/ghi |
Thanking you in advance
